SickleFlow Edge 360 ARGB image number 0
SickleFlow Edge 360 ARGB image number 1
SickleFlow Edge 360 ARGB image number 2
SAME LEGEND, SHARPER EDGE
Multi-fan Configuration
Quick Connection
Easy Installation
Hollow Frame Structure
Loop Dynamic Bearing
Addressable RGB Lighting
  • In Stock
null
NEXT GENERATION OF SICKLEFLOW FAN
Cooler Master SickleFlow Edge 360 ARGB is our new addition to the renowned SickleFlow series. This fan features enlarged blades for better cooling and a hollow frame for lightweight durability. A single modular cable simplifies setup, and installation requires only 4 screws. Enjoy customizable ARGB lighting, controllable with MasterCTRL software.
MULTI-FAN CONFIGURATION
A single-frame unit enhances internal airflow, effectively expelling heat and significantly improving cooling efficiency.
QUICK CONNECTION
Uses one modular cable for lighting and power, simplifying management and improving aesthetics.
EASY INSTALLATION
Only 4 screws are needed for a hassle-free installation.
HOLLOW FRAME STRUCTURE
This lightweight yet durable fan module, featuring a hollow design with triangular vents ensures efficient airflow and long-lasting performance without adding bulk to your build.
LOOP DYNAMIC BEARING
Features our loop dynamic bearing, our in-house bearings, preventing dust and oil leakage and enhancing operational stability and lifespan.
ADDRESSABLE RGB LIGHTING
Experience vibrant and personalized lighting effects with addressable RGB, fully controllable through our in-house MasterCTRL software for seamless customization.
Discover MasterCTRL
  • Product Number MFX-B2DN-25TP2-R1
  • Exterior Color Black
  • Dimensions (L x W x H) 361 x 122 x 26.5 mm / 14.21 x 4.8 x 1.02 inch
  • Fan Airflow 322.8 m³/h (190 CFM)
  • Fan Pressure 3.54 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Noise Level 38.5 dBA (Max)
  • Bearing Loop Dynamic Bearing​
  • Fan Rated Current 0.6A
  • Fan Safety Current 0.8 A
  • Fan Power Consumption 6 W
  • Warranty 5 years
  • Cooler Type Case Fan
  • Series SickleFlow
  • LED Lighting ARGB
  • Fan Size 360
